Aveo problemy a servisne buletiny...
Chevrolet Aveo Problems
Brakes
* Brake fluid can become dirty and may cause problems in the brake system; it should be flushed every 60,000 miles.
* Front brake rotors can wear causing a pulsation felt in the brake pedal.
Engine
* Our technicians recommend having the timing belt replaced at 60,000 miles. They also recommend having the water pump inspected for coolant leaks while servicing the timing belt.
* Our technicians recommend replacing spark plugs at 30,000 miles. At the same time, the spark plug wires should be checked and if any hot spots are found, the ignition wire set should also be replaced.
Exhaust & Emissions A loose or worn gas cap may cause Check Engine (SES) light to illuminate.
Suspension & Steering The rear wheel bearings may develop an abnormal noise and require replacement.
Drive Train Our technicians highly recommend that the transmission is serviced every 30,000 miles to avoid problems and maintain optimal operating order. If the fluid is dark in color, the transmission should be flushed.
Electrical & Lights The turn signal switch may fail causing the turn signals to stop working.
Heating & Air Conditioning Our technicians recommend replacing the engine coolant every 30,000 miles in order to help prolong the life of the various cooling system components.
» Back to top
Chevrolet Aveo Recalls and TSBs
Chevrolet Aveo Recalls (Recent)
Engine: FUEL SYSTEM, GASOLINE
Campaign Number: 06V398000
Dates Manufactured: 12/2005 to 09/2006
Number of Vehicles Affected: 17,676
Model Years Affected: 2007
Date Owner Notified: 11/2006
Defect Summary: ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH A 1.6L ENGINE, DURING A NCAP SEVERE FRONTAL CRASH TEST, THE FUEL LINE IN THE ENGINE COMPARTMENT DEVELOPED A FRACTURE. IN ADDITION, THE CRASH DAMAGE CAUSED FOUR SHORT CIRCUITS IN THE FUSE BLOCK, THE COMBINATION OF WHICH ALLOWED THE FUEL PUMP TO CONTINUE RUNNING AND FUEL LEAKED ONTO THE GROUND.
Consequence Summary: IF THESE CONDITIONS OCCURRED IN AN ACTUAL CRASH, A VEHICLE FIRE COULD OCCUR.
Corrective Summary: DEALERS WILL REPLACE THE FUSE BLOCK AND INSTALL A NEW SECTION OF FUEL LINE THAT HAS BEEN REDESIGNED FREE OF CHARGE. THE RECALL BEGAN ON NOVEMBER 16, 2006. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438.
Recall Notes: GM RECALL NO. 06133. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Body, Interior & Misc.: SEAT BELTS:REAR
Campaign Number: 04V407000
Dates Manufactured: 09/2003 to 07/2004
Number of Vehicles Affected: 32,301
Model Years Affected: 2004
Date Owner Notified: 10/2004
Defect Summary: ON CERTAIN PASSENGER VEHICLES, THE REAR SAFETY BELT CAN BECOME TWISTED.
Consequence Summary: IF THIS OCCURS THE SAFETY BELT RETRACTOR MAY LOCK IN POSITION SO THAT THE BELT CANNOT BE USED. IN THE EVENT OF A VEHICLE CRASH, PERSONAL INJURY TO THE SEAT OCCUPANT COULD OCCUR.
Corrective Summary: DEALERS WILL INSTALL A SAFETY BELT WEBBING GUIDE TO PREVENT THE BELT FROM TWISTING. THE RECALL BEGAN ON OCTOBER 15, 2004. OWNERS SHOULD CONTACT CHEVROLET AT 1-800-630-2438. VEHICLE OWNERS LOCATED IN GUAM SHOULD CONTACT GM CUSTOMER ASSISTANCE AT 1-671-648-8453.
Recall Notes: GM RECALL NO.04069.CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
» Back to top
Chevrolet Aveo Technical Service Bulletins (Recent)
Engine: ENGINE AND ENGINE COOLING:ENGINE
Service Bulletin Number: 08-06-04-023
NHTSA Number: 10025447
Model Years Affected: 2006, 2007
Date of Bulletin: 08/2008
Bulletin Summary: E108117 - 1.6L L91, REDUCED ENGINE POWER, I/P LIGHT ON, DTC P2135, THROTTLE POSITION SENSOR.
Electrical & Lights: ELECTRICAL SYSTEM
Service Bulletin Number: 08-06-04-027
NHTSA Number: 10025422
Model Years Affected: 2004, 2005, 2006, 2007, 2008
Bulletin Summary: EI08145-1.6L L91, SES LIGHT ILLUMINATED, P0420 CATALYST SYSTEM LOW EFFICIENCY, O2 LEAN LIMIT CODE P0131, P0133.
Service Bulletin Number: 8135
NHTSA Number: 10025327
Model Years Affected: 2005
Date of Bulletin: 07/2008
Bulletin Summary: ON-BOARD DIAGNOSTICS (OBD) SYSTEM AND SCAN TOOL COMMUNICATIONS-REPROGRAM ENGINE CONTROL MODULE (ECM). CALIFORNIA ONLY. CSC WAS RECEIVED.
Brakes: SERVICE BRAKES, AIR:ANTILOCK:ABS WARNING LIGHT
Service Bulletin Number: 08-05-25-003
NHTSA Number: 10025290
Model Years Affected: 2007, 2008
Bulletin Summary: ABS WARNING LIGHT ON, DTC 1200 OR 1203 SET (REPLACE FRONT ABS SENSOR).
Service Bulletin Number: 80604004
NHTSA Number: 10024425
Model Years Affected: 2006, 2007, 2008
Date of Bulletin: 04/2008
Bulletin Summary: LXT, L91, POOR ACCELERATION, THROTTLE BODY FROZEN SHUT AND/OR STUCK CLOSED, MIL/SES LIGHT ILLUMINATED, DTC'S P1516, P2106 AND/OR P2110 SET IN EXTREMELY LOW TEMPERATURES WITH HIGH HUMIDITY CONDITION AFTER AN INITIAL COLD ENGINE START OR WHIL
Service Bulletin Number: 08-06-04-009
NHTSA Number: 10024234
Date of Bulletin: 03/2008
Bulletin Summary: L91 SHORT DRIVE CYCLE, BELOW FREEZING TEMPERATURES AND HIGH HUMIDITY MAY RESULT IN THROTTLE BODY ICING CONDITION (DIAGNOSIS AND REPORT CONCERN FIRST, INSTALL PCV VALVE KIT). 2004-2005 CHEVROLET AVEO (U.S. ONLY) WITH 1.6L 4-CYLINDER ENGI
Body, Interior & Misc.: AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
Service Bulletin Number: 70941007
NHTSA Number: 10023980
Date of Bulletin: 02/2008
Bulletin Summary: AIRBAG READINESS LIGHT ON, DTC'S 52, 56, B1378 AND/OR B1382 SET (INSTALL UPDATED SIDE AIRBAG CONNECTOR).
Exhaust & Emissions: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL:CRANKCASE (PCV)
Service Bulletin Number: 4294
NHTSA Number: 10023757
Date of Bulletin: 01/2008
Bulletin Summary: CRANKCASE CONTAMINATION DUE TO COOLANT IN THE ENGINE OIL - RESEAL CASTING PLUG. WITH BUILT BEFORE VIN BREAKPOINT 8B067818 (JULY 24, 2007) & 1.6L ENGINE (VIN 6 - RPO L91 OR LXT).
Electrical & Lights: DIGITAL INSTRUMENT PANEL
Service Bulletin Number: 70849017
NHTSA Number: 10023220
Date of Bulletin: 11/2007
Bulletin Summary: SPEEDOMETER INACCURATE/DISPLAYS HIGHER THAN ACTUAL SPEED (REPLACE IP CLUSTER)
Drive Train: POWER TRAIN:AUTOMATIC TRANSMISSION
Service Bulletin Number: 70730007
NHTSA Number: 10022265
Date of Bulletin: 07/2007
Bulletin Summary: AUTOMATIC TRANSAXLE/TRANSMISSION SHIFT LEVER MAY NOT SHIFT OUT OF PARK (REPLACE BRAKE TRANSAXLE SHIFT INTERLOCK (BTSI) SOLENOID).
Service Bulletin Number: 70604009
NHTSA Number: 10021452
Date of Bulletin: 04/2007
Bulletin Summary: INFORMATION ON DIAGNOSING DTC P2106 AND P2110. LOW VOLTAGE CONDITION MAY BE PRESENT.
Service Bulletin Number: 3988
NHTSA Number: 10021083
Date of Bulletin: 03/2007
Bulletin Summary: HELI-COIL THREADS PULL OUT OF OIL PAN DRAIN PLUG OPENING - REPLACE OIL PAN.
Service Bulletin Number: 06-06-01-021
NHTSA Number: 10020843
Date of Bulletin: 01/2007
Bulletin Summary: EI06005 - 1.6L L91 TIMING BELT INSPECTION, MAINTENANCE, WORN, WEAR. UPDATED 3/31/08. UPDATED 5/15/08.
Service Bulletin Number: 60604050
NHTSA Number: 10020863
Bulletin Summary: POOR ACCELERATION, THROTTLE BODY FROZEN SHUT OR STUCK CLOSED. DTC P1516, P2106 AND/OR P2110. SET IN COLD WEATHER CONDITIONS.
Service Bulletin Number: 60604059
NHTSA Number: 10020768
Bulletin Summary: NO START OR ROUGH IDLE DURING COLD WEATHER, AND/OR CHECK ENGINE LIGHT ON WITH DTC P0606.
Brakes
Engine
» Back to top
» Back to top
Re: Aveo problemy a servisne buletiny...
odkial si to stiahol. lebo podla dátumu su to problémblaty skoro 2 roky staré
jednoducho to skopíruj a daj do prekladača
aha dikec musím to vyzkoušet ještě jsem to nedělal
[quote = "ladinek"]: PP: skoda ze cesky neumím: PP: [/ quote]
Tady si stáhni Google Toolbar Instalátor podle toho jaký používáš prohlížeč-pak stačí nainstalovat a v liště Google Toolbaru zmáčkneš na "Přeložit" a automaticky se ti celá stránka přeloží do CZ-jednoduché a rychlé
http://www.google.com/support/toolbar/b ... nswer=9230
Naposledy upravil(a) Scorpion.11 dne pon zář 28, 2009 20:50, celkem upraveno 1 x.
no přeloží to všechno celou stranku ale ten anglický text zůstane pořád stejný.
Nevadi ze je to 2 roky stare, myslite si ze problemy nezostali?
[quote = "ladinek"] ne všechno přeloží na celou stranku ale deset anglický text zůstane pořád Stejný. : PP: [/ quote]
Tak pak jsi někde udělals chybu, protože mě to aspoň funguje jak má, ale není to někdy úplně 100% přeložený, to by jsi musel nainstalovat PC Translator 2009, ale Google Toolbar úplně stačí -
Chevrolet Aveo Problémy
Brzdy
Brzdová kapalina * Může znečistit Může způsobit problémy v brzdovém systému, Je třeba propláchnout každých 60,000 mil. Kč.
* Přední brzda rotory Mohou nosit způsobuje pocit pulzace v brzdovém pedálu.
Motor
* Naši technici Doporučuji Mít načasování pás nahrazen na 60,000 mil. Kč. Rovněž doporučujeme vodní čerpadlo s kontrolou úniku chladicí kapaliny, zatímco servisní pás načasování.
* Naši technici doporučujeme nahradit svíčky na 30,000 mil. Kč. Současné vodiče Měla by Být zapalovací svíčky zkontrolovat Případně horké skvrny Nacházejí se do zapalování drátu take Být nahrazen.
Emise výfukových & volný Nebo nosi čepice plyn Může způsobit Check Engine (SES) světla k osvětlení.
Pozastavení & Řízení zadních kol ložiska Mohou se vyvinout abnormální hluk vyžadují výměnu.
Drive Train Naši technici Důrazně doporučujeme, Aby přenos je servisované každých 30.000 mil, Aby nedocházelo k problémům udržet optimální provozní řád. Je-li tekutina je tmavé barvy, Měla by Být přenos propláchnout.
Elektrické světla zase signál přepínače Může způsobit selhání blinkru přestat pracovat.
Topení a klimatizace Naši technici doporučujeme nahradit chlazení motorů každých 30000 mil s cílem přispět k Prodloužení životnosti jednotlivých komponent systému chlazení.
»Zpět na začátek
Chevrolet Aveo připomíná TSBS
Chevrolet Aveo připomíná (Recent)
Motor: Palivový systém, benzin
Kampaň Number: 06V398000
Výrobce Termín: 12/2005 až 09/2006
Počet vozidel Affected: 17676
Model Roky Affected: 2007
Datum oznámené Vlastník: 11/2006
Defekt Shrnutí: O některých osobních VOZIDEL S 1.6L ENGINE, SEVERE Behem NCAP ČELNÍM CRASH TEST, palivové vedení v motorovém prostoru ROZVINUTÉ zlomeniny. Krome, Poškození ZPŮSOBENÉ CRASH Čtyři krátké okruhy v Fuse Block, kombinaci Což umožnilo palivové čerpadlo Pokračovat v běhu palivo unikající na zem.
Důsledek Shrnutí: Galerie: Tyto podmínky by došlo v AKTUÁLNÍ CRASH, VEHICLE POŽÁRU Mohlo dojít.
Nápravné Shrnutí: PRODEJCI nahradí Fuse Block nainstalovat novou sekci palivové vedení, Který Byl přepracován ZDARMA. RECALL začala 16.listopadu 2006. Mohou Vlastníci KONTAKT CHEVROLET AT 1-800-630-2438.
Připomínají Poznámky: GM RECALL NO. 06.133. Mohou zákazníci Rovněž Kontaktovat Národní dopravní bezpečnost na dálnicích SPRÁVA ¿S bezpečnosti vozidel HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), Nebo se Podívejte na HTTP: / / http://WWW.SAFERCAR. GOV.
Body, Interior & Misc.: Bezpečnostní pásy: ZADNÍ
Kampaň Number: 04V407000
Výrobce Termín: 09/2003 až 07/2004
Počet vozidel Affected: 32301
Model Roky Affected: 2004
Datum oznámené Vlastník: 10/2004
Defekt Shrnutí: O některých osobních vozidel, jejichľ Zpětná bezpečnostního pásu Může stát láska.
Důsledek Shrnutí: pokud k tomu dojde navíječ bezpečnostního pásu Může zámkem v poloze tak, Aby pásu nelze použít. V pripade nehody vozidla, zranění sedadla cestujících do Mohlo dojít.
Nápravné Shrnutí: PRODEJCI nainstaluje bezpečnostního pásu popruhové GUIDE, Aby se zabránilo kroucení pásu. RECALL začalo 15.října 2004. Vlastníkům by Měla KONTAKT CHEVROLET AT 1-800-630-2438. Majitelé vozidel nacházejících se v GUAM, které Meli Kontaktovat GM pomoc zákazníkům AT 1-671-648-8453.
Vzpomeňme Poznámky: GM RECALL NO.04069.CUSTOMERS Mohou Rovněž Vnitrostátní obrátit na dopravní bezpečnost na dálnicích SPRÁVA ¿S AUTO BEZPEČNOST HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
»Zpět na začátek
Chevrolet Aveo Technické servisní bulletiny (Recent)
Motor: MOTOR chlazení motoru: MOTOR
NHTSA číslo: 10025447
Model Roky Affected: 2006, 2007
Bulletin datum: 08/2008
Bulletin Summary: E108117 - 1.6L L91, Snížení výkonu motoru, I / P LIGHT ON, DTC P2135, THROTTLE POSITION SENSOR.
Elektrické Světla: Elektrické SYSTÉM
NHTSA číslo: 10025422
Model Roky Affected: 2004, 2005, 2006, 2007, 2008
Bulletin Summary: EI08145-1.6L L91, SES LIGHT Světelné, P0420 CATALYST SYSTÉM nízká Efektivita, O2 LEAN LIMIT CODE P0131, P0133.
Service Bulletin číslo: 8135
NHTSA číslo: 10025327
Model Roky Affected: 2005
Bulletin datum: 07/2008
Bulletin Summary: On-Board Diagnostics (OBD) Scan Tool KOMUNIKACE-ENGINE přeprogramovat řídící modul (ECM). CALIFORNIA ONLY. KCP Byl prijať.
Brzdy: provozní brzdy, AIR: Protiblokovací: ABS varovné světlo
NHTSA číslo: 10025290
Model Roky Affected: 2007, 2008
Bulletin Summary: ABS výstražné světlo ON, DTC 1200 Nebo 1203 SET (REPLACE FRONT ABS SENSOR).
NHTSA číslo: 10024425
Model Roky Affected: 2006, 2007, 2008
Bulletin datum: 04/2008
Bulletin Summary: LXT, L91, špatná zrychlení, přívěry Zmrazené SHUT / NEBO Stuck ZAVŘENO, MIL / SES LIGHT SVĚTELNÁ, DTC'S P1516, P2106 / nebo P2110 SET v extrémně nízkých teplot s Vysokou vlhkosti stav po počáteční studeného motoru START nebo WHIL
NHTSA číslo: 10024234
Bulletin datum: 03/2008
Bulletin Summary: L91 SHORT DRIVE CYCLE, teplotách pod bodem mrazu vysoké vlhkosti Může způsobit přívěry námrazy stavu (DIAGNOSTIKA OBAVY PRVNÍ ZPRÁVY, INSTALL PCV VALVE KIT). 2004-2005 Chevrolet Aveo (pouze USA) S 1.6L 4-válec Engi
Body, Interior & Misc.: Airbagy: Celní: SENSOR / řídící modul
NHTSA číslo: 10023980
Bulletin datum: 02/2008
Bulletin Summary: AIRBAG připravenost LIGHT ON, DTC'S 52, 56, B1378 A / NEBO B1382 SET (INSTALL Aktualizováno Boční CONNECTOR).
Výfukové & Emise: MOTOR chlazení motoru: Výfukový systém: emisních limitu: bloku motoru (PCV)
Service Bulletin číslo: 4294
NHTSA číslo: 10023757
Bulletin datum: 01/2008
Bulletin Summary: KLIKOVÉ Skříně kontaminace DŮSLEDKU chladiva oleje v motoru - RESEAL CASTING PLUG. S postaven před VIN Breakpoint 8B067818 (24.července 2007) & 1.6L motoru (VIN 6 - RPO L91 Nebo LXT).
Elektrické Světla: DIGITÁLNÍ přístrojové desky
NHTSA číslo: 10023220
Bulletin datum: 11/2007
Bulletin Summary: RYCHLOMĚRNÉ nepřesné / DISPLAYS vyšší neľ Skutečné SPEED (REPLACE IP CLUSTER)
Drive Train: POWER vlakem: Automatická převodovka
NHTSA číslo: 10022265
Bulletin datum: 07/2007
Bulletin Summary: AUTOMATIC transaxle / Radici páky Prenos nemusi SHIFT OUT OF PARK (REPLACE BRZDOVÉ transaxle SHIFT INTERLOCK (BTSI) SOLENOID).
NHTSA číslo: 10021452
Bulletin datum: 04/2007
Bulletin Summary: INFORMACE O diagnostice DTC P2106 P2110. LOW VOLTAGE stavu Mohou Být přítomny.
Service Bulletin číslo: 3988
NHTSA číslo: 10021083
Bulletin datum: 03/2007
Bulletin Summary: HELI-COIL ZÁVITY vymanit se z PAN OIL DRAIN PLUG Zahájení - nahradit ropné PAN.
NHTSA číslo: 10020843
Bulletin datum: 01/2007
Bulletin Summary: EI06005 - 1.6L L91 pás načasování kontroly, údržby, stupni opotřebení, opotřebení. Aktualizováno 3/31/08. Aktualizováno 5/15/08.
NHTSA číslo: 10020863
Bulletin Summary: špatná zrychlení, přívěry Zmrazené SHUT Stuck Nebo ZAVŘENO. DTC P1516, P2106 / nebo P2110. SET v chladném počasí podmínek.
NHTSA číslo: 10020768
Bulletin Summary: NO Nebo START drsné IDLE v chladném počasí / nebo CHECK ENGINE LIGHT PRO DTC P0606.
Brzdy
Motor
»Zpět na začátek
»Zpět na začátek
