plz help my car is daewoo cielo 1996(automatic transmition)
this thing happen suddenly when i was going to my work PWR lamP is flashing then all dashboard lamps flash for 2sec and car turned off,after that i start the car normally but now when walking for about 1km the PWR lamp is always flashing and i feel the profrmance of the car decreased any idea what is the problem thanxxx
Plz Help Daewoo Cielo 1996 Pwr Lamp On Dashboard Flashing
anyaddress2
- JRD McLAREN
Re: Plz Help Daewoo Cielo 1996 Pwr Lamp On Dashboard Flashing
color of PWR lamp is ..???
..as I know no one has AT Transmission...
and no one see PWR lamp on anytime..never..
sorry ale anglicky to dohromady nedam
podle me je to pwr kontrolka motoru tedy orange.a jelikoz mu to chciplo a ted to jede malo nebo mene tak by mohla byt lamda sonda nebo mozna vypadla hadicka MAP sensor.
pokud je ale kontrolka pwr zelena(green) coz by myslim byt taky mohla tak to ma neco s tim automatem a to vubec netusim
a jeste jedna moznost snimac rychlosti tedy(vehicle speed sensor) on the transmission.
chtelo by to diagnostiku.
anyaddress2
the colour of the lamp is orange
fter checking the car with a scan tools its lead that the problem is in TPS sensor ,after changing it the same problem is still exist!!!!! also i want to ask about tps sensor,the old one in the car its colour is white,the mechanic told me that ther is white and red colour daweoo tps sensor,so he bring a white one which is the same colour to the one in my car,but i noticed that the numbers on the new sensor is different than that on my car (mechanic said this is no problem) is thats right?
- JRD McLAREN
Actualy, no one from as have automatic transaxle..
but, if you have neutral, and try push throttle pedal, engine wokrs normaly ..??
or have any kind of problem ..?? (smoke, noisly, can't accelerate ..etc.)
Orange color says, but is something wrong with engine system...but you can still drive...
Try change all slim black hoses form intake manifold to MAP, Heater control, Fuel presure valve...etc.
It looks good for the first time, but is porous.
I can't give you any other advice,..
because still don't know, if is problem with ECM or TCM ..
(engine control unit - transaxle control unit)
number tps sensor must be correct.if different number ,may be from different engine.and this is problem.
i remember problem with wire of tps sensor-conector-cut or broken
hoped from me understand
