radio, dvd, navigace,... v jednom
miura
Příspěvek od miura »
Ahoj, přemýšlím o koupi tohoto multifunkčního zařízeni. Nemáte někdo bližší info, o funkčnosti, kompatibilitě,...?
Model No.: CAV-8070CZ
Compatible with Route 66, IGO8 Tom-Tom and others based on Win CE 5.0
Can read 3D map
rds
Digital panel with 800*480 resolutions
Free Navigation software store: SD card
Can-bus, Steering wheel control function
Picture in Picture function
3D interface three colors (Blue, Red, Green)
Specifications:
7.0 inch digital car DVD player (800*400)
Double DIN touch screen panel
Built-in GPS, BT and TV tuner
rds, cdc
Compatible with DVD, VCD, CD, MP3, MPEG4, CD-R, WMA and JPEG playbacks
Intelligent steering wheel control
USB port and SD card slot
Car parking rearview
Parking close TFT automatically
Handbrake control
Electronic anti-shock protection
Full function remote control
PAL, NTSC and SECAM systems
Perfect compatibility
2 AV output, aux audio and video inputs
RCA audio output
Power: 12V DC
Mount dimension: 231*186*120mm
Advantage: GPS Store space Main frequency: 400MHZ
Main chip model number: SAMSUNG S3C2440A-40
Memory: 64MB
Store space: 64MB (can external to 4GB)
Operation system: WINCE5.0 CORE, can read 3D map
Support audio type: MP3/PCM/WMA
Support video type: ASF/AVI/WMV/DIV
Video decodes function: QVGA >25 frame/S
Software compilation type:ARMV4I
video output type: CVBS / Y/C / YPbPr, analogue RGB
Resolution: 320*240/400*234/480*234/VGA (through resistor select)
Audio output: Stereo CD quality
Audio power: Stereo 0.25W/CHANEL
Chevrolet Cruze 1.6 Basic, kráska s potenciálem stát legendou;
Ducati 748S ikona motocyklového designu.
majklfreedom
Re: radio, dvd, navigace,... v jednom
Příspěvek od majklfreedom »
Uz jsem se na to take dival, nevypada to spatne. Jestli do toho pujdes, rozhodne sem hod info o tom jak to slo. :D
Neco podobnyho jsem videl ze se dela i do myho Hacka, precejen oboji to je (nebo byla :) GM ale cena byla cca 1000€ ;)
Krtek
Příspěvek od Krtek »
Vypadá pěkně ale omezovalo by mně to
Memory: 64MB
Raši bych to levnější a s internim SATA nebo USB portem na 2,5" hadr.
Jezdim:
ex
Manželky:
Bydlim - skoro Píbram
Hanzy
Příspěvek od Hanzy »
Chlapi jak jste dopadli nikdo jste to neresili?Ja musim nebo radio mam po vodicce mrtve a ovlada se tim kus auta takze dam asi rovnou dvd nasel jsem toto a to by slo ne?
http://www.auknet.cz/p13548-dvd-autorad ... cruze.html
honza72
Příspěvek od honza72 »
K tomu "alternativnímu" rádiu a Tvému Cruzu bych měl otázku:
- po vodičce nejde původní rádio, ovladače na středovém panelu jdou? Tam jde o to, že panel s tlačítky je separé CanBus jednotka s datovým přenosem a rádio (skříňky) taky. Displej je tam řešen taky samostatně s CanBus datovou linkou a zobrazuje i nastavování auta... Bude i ten panel s tlačítky a ovladči po vodičce fungovat? Zobrazuje toto nové rádio i nastavování vozu? Jde to jen tak připojit, co jsem zatím proštudoval, tak std. rádio jede jen s VIN kódem daného vozu a pro jiný VIN se musí k diagnostice na přeprogramování. On vůbec ten CanBus po zapnutí "zapalování" posílá na uvítanou všem jednotkám VIN auta a očekává naprogramované odpovědi, jinak problémos...
Ex. Cruze, Kalos, Nexia
Hanzy
melo by to fungovat vse canbus taky i ovladani na volantu by melo vse fungovat toz uvidime a kdyby nekdo chtel ukacema nakou slevu i :D
mam objednano tak kdyby nekdo mel zajem tak rychle.
Origo zmetek obycejny stoji 15000kc tak to muzu prdet a ovladani radia nejede nic bez radia nejede.
vetr.roman
Příspěvek od vetr.roman »
ja jsem o tom taky uvažoval ale je to palka, pobočku v Brně namaji,takže se musi až do Č.B,.Za montaž si učtujou 2500.-Kč bez DPH a maji čas až v polovině ledna.A doba montaže je 4hod.
Slevu na jeden kus nedavaji,ale komunikace je dobra snima. -i
http://astoncb.cz/p5890-dvd-autoradio-s ... cruze.html
Lada 2101
Škoda Forman 1.3i
Nissan Almera 1.4i
Daewo Kalos 1.4i
Nissan Note 1.4i
Ford Galaxy III 2.0 TDCI
SERGEJ_3
Příspěvek od SERGEJ_3 »
jo tohle je presne to same jako na tom auknet.cz, ja bych do toho sel hned, ale kvuli montaze se mi do CB nechce, a je dobry ze ti zarucuji ze neztratis zaruku, to se mi libi -i
Prodám : pružiny H&R -30mm
www.chevy.tym.cz
Hanzy
Ja to mam od nich a montaz zaden velky problem ale nechal jsem to delat u Horecky v Kunine do 2 hod a bylo namontovano jsou tam sikovni kluci ;)
Jde to ale i svepomoci zaden problem velky ja tam byl kvuli jinych veci a pri jednom jsme to tam soupli.
SERGEJ_3
takze u Horecky jsou ochotni to namontovat,jo? tak to potom neni co resit, pockam kolik dam za kola a potom se vrhnu na tohle radijko...
www.chevy.tym.cz
vetr.roman
Dejte sem info kolik to stoji i z montaži v autor.servisu + foto a jestli je vše v češtině.a jestli to ukazuje na displeji venkovni teplotu. :PP:
Lada 2101
Škoda Forman 1.3i
Nissan Almera 1.4i
Daewo Kalos 1.4i
Nissan Note 1.4i
SERGEJ_3
tak v cestine je navigacka, nastaveni auta jde videt i v tom videu ze je v anglictine, ale ta teplota me taky zajima...
www.chevy.tym.cz
Riko
Příspěvek od Riko »
Hanzy píše:Ja to mam od nich a montaz zaden velky problem ale nechal jsem to delat u Horecky v Kunine do 2 hod a bylo namontovano jsou tam sikovni kluci ;)
Preboha tak keď to už máš tak nevieš napísať či všetko povodné funguje,klíma,ukozovateľ vonkajšej teploty atď?
Vďaka!
SERGEJ_3
neboj napise :mrgreen: jen si ted asi dela melir tak nema cas :lol:
www.chevy.tym.cz
Zpět na „Cruze - Elektronika“
