Právě je pát úno 15, 2019 21:07
Všechny časy jsou v UTC + 1 hodina
Odeslat nové téma Odpovědět na téma  [ Příspěvků: 3 ]
Autor Zpráva
 Předmět příspěvku: Espero spark timing adjustment
PříspěvekNapsal: úte úno 14, 2017 22:04
Offline
Nováček
Nováček
Hello friends and greetings from Romania!
I have looked everywhere and I can't find the information I need. I want to adjust my spark timing, and I have no ideea at what angle BTDC it has to be. From what I've seen, I have a mark on the harmonic ballancer (the big pulley where all the accesory belts connect to the crankshaft, I'm not sure that's how it's called) and a scale on the timing belt cover. Autodata and some pdf file I found say I should set the timing to a different mark, something like a pin, way more to the right. Autodata says I should adjust to 15 degrees, english pdf file says 8, and the service manual does not mention anything. The ecm gets the lowest spark timing advance value at 8 degrees, but can you confirm that's the value to aim to?
Also, I will have to make the ECM hold the ignition timing steady, not to bounce from 8 to 16-20 degrees as I can see on the laptop. Any ideeas of how can I do that?
The timing lamp is DIY, pretty simple, it cost me like 2 euros and it took me 30 minutes to assemble it. I can share schematics, or you can find them on google if you want to adjust your ignition systems too
Thank you for your time and sorry if I made any mistakes, english is not my primary language
Nahoru
 Profil
 Předmět příspěvku: Re: Espero spark timing adjustment
PříspěvekNapsal: pát úno 17, 2017 18:53
Offline
Nováček
Nováček
I've got it all sorted out. I'm replying to leave some info here for you. You need to start the engine in diagnostic mode (wire between A and B in the diagnostic plug) and the timing will not change. My car started bad, third try only, i believe fuel pump does not work until you start cranking this way, but I got it started and adjusted the spark timing. 8 degrees BTDC, all is good now. I don't know when I'll be logging in here again, I can't understand anything. If you have any questions for me regarding this, or diagnostics software/cable, or just anything, email me at ionita.mihai01@gmail.com
Nahoru
 Profil
PříspěvekNapsal: pát úno 17, 2017 22:28
Offline
Chevy master
Chevy master
Hi,
first : timing belt must adjusted correctly in it's right position
mark on timing wheel must be in accurate position, both on wheel of crankshaft ,also on camshaft
After spark-distributor can will send spark signal for ignition at right time
That's all.
Nahoru
 Profil
Zobrazit příspěvky za předchozí:  Seřadit podle
Kdo je online
Uživatelé procházející toto fórum: Žádní registrovaní uživatelé a 0 návštevníků
Nemůžete zakládat nová témata v tomto fóru
Nemůžete odpovídat v tomto fóru
Nemůžete upravovat své příspěvky v tomto fóru
Nemůžete mazat své příspěvky v tomto fóru
Nemůžete přikládat soubory v tomto fóru
Hledat:
Přejít na:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Český překlad – phpBB.cz
Naše projekty: | Opel Forum | Astra G | Astra H | Astra J | FiatClub | HyundaiClub | KiaClub | NexiaClub | SuzukiClub
